What page are you questioning? What were you expecting as far as improvements in performance?
The Hi-6 box gives a multiple spark at lower RPM's then defaults to a single spark as the RPM increases. Noticeable improvements sould be pretty much limited to better starting and better ignition at idle/lower RPM. High speed operation will be pretty much the same as a standard ignition. At least that's what I noticed with my installation.
