hmmm, so some of you would rather pull, some would rather push.....pushing just seems so much easier (like I said, probably from being used to my slapstick - both hands on the wheel, when you need the next gear just hit the shifter and hand back on the wheel (i got manual steering).... but the drwback i found out is that i need a forward exiting cable if i want to push with a reverse manual valve body...maybe i'll just have to try it both ways?
