On my tensioner plate, i drilled the 4th hole and bolted it on. The tensioner plate has an oiling tab.
I did not drill a oiling hole in the plate where the oil galley is (no problems so far), but it might help. I just would not go too large with the hole because it could reduce your oil pressure/volume going to the bearings.
