Leave the pipe nipple alone.
get everything off of the pump/housing to lighten it, break open all the bolts a hair then take out all of them ex the "one" then grab the housing w your right hand around the tstat neck to support it as you undo the bolt w a 9/16" open end wrench in your left hand supporting the housing as it comes out. On your bench if you have a hot wrench I would get the nipple out. As said unbolt the 2 front pan bolts so the tcover can come off
