thanks for those numbers.
I fixed the backwards hp labeling problem but left the calculations as is for now, which means my calc is using pretty much the same formulas as all the other calcs on the net. Basically a mathematical guess.
Oh well. At least you don't have to type in numbers and hit 'submit' over and over and over again. That was my goal.
