The O2 sensor on my 2002 Sebring coupe just turned my check engine light on,so I'm wondering if they are repairable or do I have to replace it? I was thinking I may be able to pull it out clean it up and go! What do you guys know about this?
Thanks!
Usually what happens is the heater shorts out inside the sensor. No amount of cleaner will fix that.
