Can you tell anything from this pic? Second trip to the track with this setup. First time we only made motor shots and I was able to pull a 1.48 60 ft. This is with a nitrous convertor and 4.30 gears on a footbrake. Left at 1500 rpm, 9 inch wide slicks, truck shocks in the back 3" longer than stock for more travel, superstock springs, 7* nose down pinion angle, and no snubber.
Went back to the track second time and hit the car with a 180 shot out of the hole and still sixty footed a 1.48 but annihilated the tires at the line. Tire pressure is set at 12 pounds.
Can you tell anything from the pic? This was the nitrous pass, I am wondering what would be the next step to making it hook out of the gate on the 180 shot? Should I go with the adjustable ranchos?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
