Jimmy(bad1970dust) gutted my 446" this afternoon...Here is what he found...Cam was junk,had a wiped lobe. Two cylinders were scared..Should clean up at .055 over. Rod bearings were shot. 1 main bearing showed some scars. 1 piston was chewed up on the bottom and probably some other things I forgot!! Looks like back to the drawing board!!
