As the OP stated wooden handle check works well. So that its not as messy use some 2 1/2" masking tape and run it around the bottom of the head after you have the valve cover off. This will build a temporary dam keeping the oil off of your exhaust. Drop a shop towel on the manifold side to catch the "flying oil" as it comes off the rockers.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
