Make sure the cowl drains are open and it isn't filling up and running over into your heater.
Exactly, I remove the cowel screens from time to time and use a shop vac. You can use air hose to blow out the drain holes too, I think there are 3 of them. Then I use the shop vac again to suck out whatever I moved around with the air hose.
