Tubs are at the anodizer....will be finished tomorrow. Need to do some paint work to get ready for them though.
Anodized .... arent we trick...
No....just almost as cheap as paint plus keeping them light in color will make it easier to see under the car. If you want to see trick & fancy, you should see the tub liners.
Looks great! If you want to stop the "out dings" use roll on bed liner on the under side
