I agree with the E85 makes it more economical to race and will have my car burning corn again soon.
However if E85 is not available around you or you do not want to convert your carb you will be fine with 92-93. I have about the same setup as you 11.1:1 comp ratio 440 with eddys. I run strait 110 when I race but see no gain. My main reason for running it is consistency of the fuel. You dont always know what is coming out of the pump.
If the car is going to be a driver and an occasional racer I would run 92-93. If shes not running as consistent as you would like her too dump 5 gallon of 110 in when you get to the track.
