hi i had two customer cars this year with the same problem.i used a sazall it took three blades each bolt aprox time 30 min .i cut at the rubber with the lip as a guide with the arm at full up position. it wont seem like progress untill you pass the hardend outer edge of your bolt then it gets easier good luck
