Re: Horn relay
[Re: shadetree72]
#637117
03/12/10 11:38 PM
03/12/10 11:38 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I searched "relays" in general and started looking at all that were listed until I found the one that looked like what I had. It worked as far as a horn relay, but I don't know about the key buzzer as mine didn't work when I got the car-72 Challenger. My relay plugs directly into the fuse box, I'm not sure what your setup is. Good luck, hope this helps.
71/73 and lates E and B bodies uses same configuration and everything than A bodies BUT the bracket attached to cover. If Somebody is not able to find the one with brackes and get one without the brackes and STIL HAVE the old piece, you can remove the covers and interchange, fitting the new piece into the old piece cover with the bracket... voila!
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
