I remove the piece of plastic on the crimp area of the terminal slide a piece of shrink tube on the wire crimp the terminal with a set of panduit crimpers then solder the wire/terminal then slide the shrink tube over the crimp area of the terminal and shrink it this makes a perfectly conductive permanent connection
