'65 dart drivers side 273 ex manifold on a 83 318. leaks out the bottom side on the manifold on cyl 5 & 7. I know the contact area is thin so should I ride the gasket high as it will go & WHICH gasket should I use?? thank you for your time. this will be my 4th time on this,I want this to be it PS I did plug the air injection holes.
