I think that would be a good combination with the 516 heads. The 516's have a flatter floor like the 452's but a closed chamber. You will be able to get better quench with the closed chamber.
just my
I run a flat top with the closed chamber 915's that are milled to death and only have 12:1 with the piston -.005 in the hole.
