Thanks for the replies. I think I have about 1-1/2" clearance, but I have not measured it. I wanted to see if anyone had experience with the OEM dual snorkle air cleaner. Sounds like I will have to modified the air cleaner if I go with the RPM.
440abody - What drop base cleaner did you use to have the same diameter air filter?
Ron
