Cam would be a comp xe275hl, around here it's pretty flat and usually around 1000ft above sea level.
Main problem is, the last known place that has 94 is the place 5 minutes away from my house. It seems only a select few places in Manitoba sell anything higher than 91. 91 is the standard 'premium' most places sell, however I have been through some towns where even that is not available, just 87. I'm fairly confidant I'd be fine if I fueled up everywhere 91 or higher was available, but you just never know right...
