Crankcase vacuum stabilizes the ringpack and allows a better seal. You should also use a low friction oil control ring and that frees up some more. If the crankcase is pressurized there will be some resistance against the piston bottom as well.
Thanks Bob
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
