Quote: I know you can kill a circuit by either cutting its ground or positive feed.
Right..the universal AAW cuts the ground. It's a GM setup. I don't know what MOPAR breaks....the ground or the positive. You won't be able to use switches that cut the positive with this harness. I recommend calling AAW and tell them you are wiring a MOPAR. If MOPAR breaks the positive like Ford does you can't use any of the switches that break the positive like interior lights....door jamb switches. The switches that come with the universal kit are for a street rod set up.
