I was just correcting you where you said that you doubt you can go from a 3.91 bore to a 4.040 bore by saying it has been done. Good advice on the longer stroke though, it is a lot more reliable.
But, if you have some old 340 pistons and a thick 318 block both sitting under the bench...
-dulcich
