Re: Any turbo'd 3G hemi's???
[Re: Curt]
#618879
01/29/13 11:48 PM
01/29/13 11:48 PM
Posts: 33 Calgary, Alberta
Turbo392
Calgary, Alberta
Hey turbo 392... Any progress, education you can share? Thanks Curt
Sorry, I missed this thread. I had the engine built with a 6.1 block purchased new back in 2006. Stock bore with a re-ground stock forged 6.1 crank, Honda journals. Diamond pistons, Ferrea valves, Carrillo rods, ported 5.7 heads, 8.5:1 compression. No stroker kits existed back then. The origin 5.7 engine ran a STS turbo kit for a year until I got greedy and popped the ring land on #3 piston.
Now several years later I've built my own rear mount turbo system and 2 front mount systems for the same long block. Currently running a front mounted Borg Warner S480-96mm 1.32 a/r with meth injection, nitrous.
2003 Dodge Ram 1500
Turbo / Meth Injected 6.4L Hemi (392)
