10 inch rim, an 4.5 backspace should fit, but be close to the spring and the car will need to be raised with some tight springs(or worse case, air shocks) to avoid being stabbed by the upper wheel lip on a bump. it would sit flush with the outer most part of the 1/4 panel.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
