Thanks for the input. The motor is stock 440 bore and I checked valve clearance on a 440 and it looks fine. The pistons have some pretty decent reliefs, and I plan on checking clearance there. The heads are off right now waitting on parts. I think quench is gonna be a strech at .025 in the hole, and a .039 head gasket. I was thinking about putting on a thick head gasket to drop the compression a tad since now would be the time. dynamic calculator says my CR should be 10.7 to one.
1968 Plymouth road runner 1968 Dodge Coronet 500 64 D200 Good, Fast, Cheap. Pick Two.
