well I feel a lot better today realizing the failure was probably not due to my inexperience with NOS. General consensus is broken valve. Half the lock from the intake valve is missing and the other is almost out.
Fortunately the block can be sleeved and the head can be fixed. Hoping the crank is ok??
If you don't mind, what was your jet spread and timing?
Wayne
sorry, did not mean to ignore you. NX twin perimeter plate with 41fuel 62nos X 2, taking out 6deg. total timing 31
Same combo went 7.57 3 weeks ago.
