Quote: I finally found out what these wheels are! They are a Rader wheel, offered for sale at select performance dealerships such as Motion. The ones I've found online have a GM bolt pattern only, which is no good for my Mopar.
If you really want to run the wheels, why not just redrill the axles/hub on the car? (assuming you did not want to redrill/insert the wheels for what ever reason)
