I called hughes and they told me the early 340's piston came out of the hole a bit, and to measure it to get an idea how much gasket to use. thanks
I was trying to help..but I guess your all set.....If you talked to them,I would be asking them these questions...
I know later 96 up 360 magnum heads are diff.. good luck
