I have attached some documentation I've found about the WIPERS-OPERATION (on page 2 of the schematic). It appears the PARK switch is built into the wiper motor assembly as Ronnman suggested. With this information I believe the schematic should be correct if we use the "thick VIOLET" wire vs. the "thick RED" wire. Do you agree?
