My car stalls out in gear and I'm wondering if the torque converter is bad or not installed properly... the mopar book states that the when the TC is installed you'll have 3 distinct engagements...is it possible to hook the trannie up with the TC not engaged fully(2 engagements) I have no leaks and the motor runs in nuetral and park but when I put it in gear ir stalls evrything seemed to have lined up properly to the flex plate when I installed it
