Fan Blade w/o A.C. V8 exc. 7-Blade 2863224
Fan Blade w/o A.C. w/318 4-Blade 2265034
Fan Blade w/o A.C. w/426 7-Blade 2863216
Fan Blade w/o A.C. w/440 5-Blade 3462150
Fan Blade w/A.C. w/198, 225 4-Blade 2780920
Fan Blade w/A.C. V8 exc. 7-Blade 2863216
Fan Blade w/A.C. w/318 5-Blade 3462150
Fan Blade w/Hi-Capacity w/198, 225 7-Blade 2863213
Fan Blade w/Hi-Capacity w/318, 340 7-Blade 2863227
Fan Blade w/Hi-Capacity w/383, 440 7-Blade 2963223
for 1971
Caution is required when using the parts catalogs for original application questions. I went through a number of broadcast sheets and compiled the following list. I have added full part numbers from GG's "white book" and it appears the "216" 7-blade fan was used to a greater extent than the list above would lead one to believe. I thought I had more A-body sheets.
1971
318 auto a-body w/o A/C FAN - 24 (2863224) & SPACER - 55 (1730155 1.40" spacer)
440 4-spd b-body w/3.54s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
HEMI auto b-body w/3.55s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
383HP auto b-body w/3.91s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
383HP auto b-body w/3.23s FAN - 24 (2863224) & SPACER - 10 (2120510 1.60" spacer)
HEMI 4-spd e-body w/3.54s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
HEMI 4-spd e-body w/4.10s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
HEMI auto e-body w/3.55s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
HEMI auto e-body w/3.23s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
440+6 4-spd e-body w/3.54s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
383HP auto e-body w/3.91s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
383HP auto e-body with A/C FAN - 16 (2863216) & SPACER - 60 (2863260 thermal clutch)
383HP auto e-body w/o A/C FAN - 24 (2863224) & SPACER - 10 (2120510 1.60" spacer)
340 4-spd e-body w/3.55s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
340 3-spd e-body w/3.23s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
340 auto e-body w/3.91s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
340 auto e-body w/3.55s & A/C FAN - 16 (2863216) & SPACER - 07 (3462107 thermal clutch)
340 auto e-body w/3.23s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive)
318 auto e-body w/o A/C FAN - 34 (2265034) & SPACER - 36 (2265036 2.20" spacer)
318 auto e-body with A/C FAN - 50 (3462150) & SPACER - 46 (1674746 1.72" spacer)
318 3-spd e-body w/o A/C FAN - 34 (2265034) & SPACER - 36 (2265036 2.20" spacer)
