Quote: That undercoating looks sweet. What is Transtar? I googled it. Didn't find anything.
I used 2 coats of 3M Body Schutz #08864 and a thin coat of Transtar 4361F quick dry rubberized undercoating over the top. The Transtar I put on was strickly to give it that factory looking sheen since the 3M Schutz is to dull. The tip I made is from copper pipe that I threaded and smashed the end so I was spraying through a slot instead of a hole.
