I just got a set of W5s with the TD rocker setup - it is a very sweet setup and appears very durable. Each pair of valves has its own shaft and rockers so if you did have a failure you could replace just one rocker set.
Don't forget to plug the oil hole - neerly missed it -whew.
i can send pics if you like - send me a pm.
