How much amperage can the stock starter relay handle ?
My car is getting the painless harness installed with several relays being put into the system(headlights, taillights, fuel, stereo system, wipers) I would like to pull power for them from a central source and the relay is nicely located. If it can't handle the draw, are there any other higher amp starter relays that I can use in the place of the stock unit ?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
