I ended up using an old Hurst ratchet shifter from a swap meet. I cut the handle off short and bolted on an old 3-speed shifter handle. Except for being a long-throw between gears it seems to work pretty good and has the look i wanted. I also used an old b-body console lid and built lower sides for it to form a custom console out of 18ga. steel. It is funny what you can do with more time than money. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
