dont run, never have, never will , dont need them unles youre a top fuel , pro stock car or something like that no need do what ever tho
I'm going to strongly dissagree with this. Perhaps YOU have never needed them, but most guys that run bias-ply slicks with tubes on a car thats 60's under 1.5 are likely dealing with beads moving on the rims. Last year we watched my buddies nova slide the slicks 6" in just 4 runs (10.90's, 60-ing at about 1.5 & out the back door at 125ish) This can be a major safety issue as the tube which is pressurized to the tire will want to move with the tire. The valve-stem in this scenario will be the weak link. You want to blow a tube at 130 mph?? Have at it.... Me?, I'm taking the safe & simple option of adding a couple of screws to the rims.
LemonWedge - Street heavy / Strip ready - 11.07 @ 120
