Rick, i`m looking fwd to those wires.
As far as the dyno testing, Jeff`s right with the water temp. When i`m at the track i like to keep the water temp in the 100/120 area if possible. FAST is a heads-up class and i need to go fast. AS far as dyno`ing with the water pump, alt, air cleaner, etc,etc... I dyno lots of engines, i have a plastic container with the stuff i bring when dyno`ing a motor. Bottom line it`s just easier for me, that `s the way i do it. I`m just using the engine dyno as a basic tool, i`ll do the fine tuning on the rear wheel dyno or at the track while i`m using the complete exhaust system, fuel system, and all the stuff we actually have to run with, in the car were using.
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
