Ok now it's idling 800rpm @ 9" in neu. and 600rpm @ an unsteady 2.5" in gear(wavers between 0-5 with engine rpms). Messing with the mixture I can't make the unsteady go away, go any leaner and it stalls and richer doesn't help either.
i was wrong about the Timing, it was actually 10 BTDC and is now 15(ported vacuum no vac. advance at idle)....I may go back to 10 as at least the in gear idle was steady. For some reason this car is doing better than it has in a long time. Thanks for all the help and encouragement.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
