Re: Installing a 10.95 clutch
[Re: 68LAR]
#581412
01/13/10 09:03 PM
01/13/10 09:03 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
The first thing you will need to do is verify that the 10.95 (11") will bolt up to your flywheel. I'm pretty sure they (10.5 & 10.95 or 11), have different bolt patterns. As far as the attachment bolts, stock bolts will work, but must be at least a grade 8. Summit has them listed. 3/8-24X1 I believe. The part number you have for CenterForce is correct.
So while they are 130 tooth, they are two different flywheel bolt patterns? I assume most of the aftermarket (hayes, mclead, centerofrce, etc...) will have both patterns or would that be too much to ask? Anyone know for sure?
