I find there are too many downsides to head milling. A clean up is ok but to raise compression ratios due to low piston heights it's a bunch of cutting for little gain.
Intake bolts hard to line up, valley pan not fitting properly which equals oil sucked into intake ports and will usually create pushrod length problems.
