If the pieces in there were positioned correctly which I'm sure they were as you'd have a ton of play if you had them sideways I'd say just a (very rare) defect in the metallurgy. I'd grab a new kit (only $10-12 or so) & I think you'll be fine but I would give everything inside the coupler a good visual inspection.
