My goal is to first lighten up to at least 3600 race weight.
I have glass bumpers already painted silver and hood with raised (4")RO scoop, used magnum force front end (500 miles)with manual rack. Install motor plate,low mount mini alternator. Pull engine out to freshen up,install girdle,maybe change heads and cam, declutter under the hood while the engine is out,fill in holes and repaint car. Check air in tires after I get all that done
If all that works out then maybe run some 9's in street trim.
