The inner seal separates the wheel bearing from the differential fluid. The outer seal keeps the grease from the bearing away from the brake shoes and prevents dirt and fluids from contaminating the bearing.
There are 2 different sizes of inner seals, depending on the year.
Send DoctorDiff a PM, he should be able to help you with parts and advice.
