One more thought. Do you know for sure you have a 383 base plate? Because they are unique to 383s. Most places will try to sell you a 440 and tell you it will work -- wrong. The 440 baseplate's carb fitting is a different height than the 383s. If you use it, then the 383 rod will be the wrong length.
Until total honesty is on the table, we're not even talking about reality...
