I used White Post for a 70 E-body booster and m/c but I won't use them again. They turned the parts quickly and all appeared good but I had some follow-on questions about the m/c after the work was done when I learned that the aftermarket piston kits for those m/c's are problematic. I got a ton of attitude from the guys from White Post when I tried to find out if they used my original pistons, etc.. They got pretty condescending and wouldn't even entertain the notion that they could have made a mistake.
I ended up having to get the m/c done again and I used these guys with great results:
Brake & Equipment Warehouse
455 Harrison St NE
Minneapolis, MN 55413
612-767-2629 – I spoke with Brad
BTW - My m/c required a sleeve. White Post uses brass sleeves and Brake & Equipment uses stainless. I believe stainless is better.
I haven't used Booster Dewey, but I've heard a lot of good things about his work.
Booster Dewey is super guy who does a really nice job...
