I need to replace the trans cooler lines on an '06 Liberty, and was told that a special tool is needed to disconnect/connect the lines. I was also told that the lines are not easy to replace with the vehicle on a hoist, and may be nearly impossible on jackstands. Can anyone point me in the right direction on this? Thanks in advance!
It's Swifty! Swifty, you toad sucker!
