it's hard to explain with out pics but here's a try if you use a net with an angle on the bottom .
you can weld two small lengths of tube on the shoulder bar slightly wider than the net. put a rod thru the net and it slides right into those tubes. you put the rod into the front tubes first and slide it toward and into the rear tube. a pin holds it in place.
'I know no pics
Thats what I use for my bottom bar on my net, has
the seat belt lock on top.... right now the top
slides into a tube(like the bottom) at the rear and
the seat belt lock at the front.... I'm going to
change the top rear point to a hinge
