Make sure you get the springs for the cam you are running or have the Pressure checked. I always tried to find a set off a lower mile 400 or 440 because the Rockers do get thin with a lot of miles and will push through. Make sure the Shafts are not scarred from the Rockers also. New ones are cheap compared to damage if something binds up or lets loose.
