Does your clutch fork pivot on a ballstud or the more common clip type pivot? You will need to change the flywheel/clutch also. Both styles of SB O/D bells are 10.5". /6 Truck used a 9.5" wheel with a 10" clutch. We can set you up with the parts you need to do the swap.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
