Currently, it is a 500 inch with box rpm heads and a tiny roller cam. Mild
Here are the specs on the procharger
Procharger D1X Specs:
Max CFM: 1900
Max Boost: 32psi
Max Impeller RPM: 58,000
Outlet ID: 2.62"
Outlet Hose Diameter: 3.00"
Impeller Exducer Dia: 6.6"
Inducer Diameter: 4"
Inlet Hose Diameter: 4.25"
Compressor Housing Diameter: 9.75"
Internal Step up: 4.44:1
It is capable of making more but I am looking at the 800hp area with about 12-14 lbs of boost.
We will see if the intercooler is up to the job.
